airmech3839
- 5
- 18
- Augusta, GA
Ok...recoverd her and got her home....
Here is what I found....
1. supply line kinked..... opened up a little more with a big philips screwdriver from inside...gently.
2. turned on pump and it pushed fuel but fuel was more water and sludge than actual fuel....hooked up lines
3. Drained 12gal of all the fuel from tank....just happened to have 5 gal buckets in truck along with 55gal drum in the back. went and got 10gal of clean fuel and rinsed tank with about 1-2 gal and put 5gal in tank and turned on pump...went down the line and drained all the filters....then cranked her...
SHE IS ALIIIVEE!!! she roared to life and fluttered for a minute or two then finally smoothed out....cleaned up and hit the road with chaser car!!! she has more power and wants to run!!! got her home in the stable and let her run a little with throttle out at about 1200-1300rpm to make sure she has cleared out the phlem!!! Shut her down and I am now trying to clean up the mess!
Tracy
Tracy
