Cartridge filters
sht2kll
Spring Creek / Nevada
Howdy all: I have been looking at threads for a week now. I got a pad of paper out and started writing all kinds of great information down. Now my pad has disappeared, I think Aliens landed and abducted it. I have an M1008 and would like to install different filtering systems ( fuel and oil) on my truck, either spin-on or cartridge. I remember from some threads thet Racor filter adaptors are used by some. I would like to find some that are adaptble without extensive fabrication, other than brackets and fluid lines. I am planing on trying waste oil mixture for fuel. any suggestions for adaptors and filters? Thanks Tom
T_F_E
Metaline Falls, Washington
Racor makes some great spin on filter systems. They are pretty expensive though. I have a racor #445R and love it, it has a primer button that makes bleeding the whole system really easy.
southdave
ripley, oh/TDY Lordstown,Oh
I just got butt load these off GL for the min. kinda of ironic I also got 150 dip sticks I MUST STAY AWAY FROM GL, I know they are expensive Hyd. filters I considering useing the primary and seconary off big old detriot they are big but cheep
southdave
hydraulic oil hc9600fks4z outragous what the element cost 71 bucks each and still 15 micron of filtering I don't want to know what the housing cost . as for the detroit off the top of head the seconary is a fram 1147a I am going to run crap fuel
I posted these pics of the fuel filter I use on my 3 CUCV's.
In this thread below.
http://www.steelsoldiers.com/cucv/3...using-new-filter-didnt-fix-issue-what-do.html
These are a spin on filter / water seperator that use the standard mounting holes as the stock military filter base but this one does not leak like the stock setup.
BTW The element is a napa unit part # 3418.
The element comes in a short and a tall the element in the pics is a tall its about $15.00 - $20.00.
This filter base can be found on civilian trucks that have the 6.2L or 6.5L diesel engine.
Hope this helps.
http://www.steelsoldiers.com/attach...sue-what-do-ac-spin-fuel-filter-adapter-1.jpg
http://www.steelsoldiers.com/attach...sue-what-do-ac-spin-fuel-filter-adapter-3.jpg
http://www.steelsoldiers.com/attach...sue-what-do-ac-spin-fuel-filter-adapter-2.jpg
Screamin' Metal
SW Oklahoma
Check out Racor....if they're not to your liking....Trans-dapt carries a full line of spin-on fuel and oil filter blocks that go down to 10 microns. If you want quality...get stanadyne heater and filter all in the same unit for about $100, You can even get them with a built in lift pump and a filter change indicator....
