glow plug temperature switch
abarkus
pittsburgh/pa
Hi i need the corect part number for the temp switch on the glow plug system. I have broke mine when i did head gaskets. Bought one from rock auto it had two spade connectors on it. So i change to spade connectors. Glow plug do not work when connected. take off the wires and it works. Change wires on the temp switch and it would not work take off wires works. I type slowley.
jdemaris
I assume you mean the two-prong glow-plug inhibit switch? If so, it doesn't serve any useful purpose. Just bypass it and join those two wires together. GM used it in the early years to stop the glow plugs from working once engine coolant temp was 125 degrees F or higher.
jdemaris
I hope that someone has a used one with pigtail for sell off old motor
I'm still don't understand exactly what temp switch you are referring to? The two-prong switch used in many 6.2 diesel glow plug systems is the "inhibit switch." It has two prongs on top and there is full continuity between them until the switch reaches a temp of 125 degree F. Then it opens and prevents the glow plugs from working. Easy to buy, easy to replace, and easy to do without. GM later eliminated it anyway.
ida34
33
Dexter, MI
It is not the same as a cicy setup. The temp sensor in the cucv setup provides constant variable resistance to tell the glow plug controler how long to run. The temp switch he is refering to is on teh back of the head installed in one of the crossover block off plates. The old style on the cucv had a circular connector with a center pin and outside contact. The newer style switch has two blade connectors and should come with a pigtail to splice in. The replacement is straight forward. Yellow wire to yellow wire and black to black. I have one and I can try to find the number tomorrow. I will also try to post a pick. The temp sensor is needed or the glow plugs will not work in the cucv system.
abarkus
pittsburgh/pa
Any luck on finding the part number and where to get one from. It helps the glow plugs from not coming on all the time when not needed.
TyJustice
Denver
No problem.
I bought a few of them last year to be used as spares. I can see this part being hard to find someday.
ida34
33
Dexter, MI
Is the pictured one like the one you got. I did not have time to look for it today. I hope to have better luck tomorrow. We had a death in the family today so very little work got done.
********update for those that need info regarding the coolant temp sensor*****
Oreillys part#WT3000 Coolant temp sensor (1/26/2013) Price $17.99
Oreillys part#pt191 Pigtail Connector for above coolant temp sensor (1/26/2013) Price $22.99
forest522
Bernalillo, New Mexico
I replaced mine too, with one from CUCVElectric. Replaced the GP card too. Still didn't work right, so I left it unplugged. Seems to to have been fine without it. My local 6.2 diesel mechanic recommended just leaving it unplugged. Apparently it was a GM problem. Mysterious.
forest522
Yes, had two of those as well. Both switched off the re-glow period after slight warm up. Not sure what the deal is. Card is new as well. But, good news is, it's still unplugged and there has been no issues so far. Plugs get run every time and I guess that is ok. Thanks for the reply though!
Small Prepper
Gernantown, MD
Afternoon
Question: Coming out of the fire wall I have an Blue wire along with the Coolant temp sensor wires (Yellow and Black) (In the same hole) It has an lock type connector on the end of it. Dose any one know what the blue wire plugs into?
I looked around and can't find what it goes to. I also looked in manuals and can't seem to find anything there.
Thanks for any help you can give me
S.P.
