Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
I may not be answering your question, i'm sure the guys using these trucks had to settle for something different than the specified dot 5 from time to time, and I bet anything will work if not mixed improperly (dot 3,4,5,syn,non syn...)
if I read this right.....you cant tell the difference. I do agree with the TM's on the syn recommendation.....it's all about base ingridients and how they react to/control heat.....you might have to be more specific...
it doesn't matter what was in it when you got it you should drain it all out and start with fresh new fluid in every system on the truck because is you life or someone else's or even you truck not worth a couple hundred dollars?
