Barrman
- 1,782
- Giddings, Texas
I have always felt and heard the rear axles shift side to side when I make sharp turns in both running M35's. Two weeks ago, I took the Gasser on a 40 mile round trip pulling a M105 to get gravel for my drive way. The guy at the gravel pit loaded me up too much. 8.86 tons! I didn't want to shovel it out, so I paid and started home very slowly. The first sharp turn made the axle shift seem very loud. It drove fine though if just a bit slow on the hills. Everything looked ok all over the 3 times I stopped to check.
I got it unloaded and didn't drive it again until going to a Scout meeting this Monday. It drove great, but pulled to the right some. I was thinking low right front tire, right front wheel bearing going out or sticking brake. The tire looked ok, so did all the others. None of the hubs were even warm and non of the brakes had any heat at all in them. I figured the bearing was the problem and just decided to drive slow the 5 miles home after the meeting.
I got about half way home and the truck just didn't want to go fast. I had a guy following me real close wanting to pass. He got so close that I couldn't see his lights in the mirrors even, so I looked out the back. He wasn't that close to me. I was leaving a huge smoke cloud that dimmed his lights! I got off the throttle and he shot around me. Except for the right pull, everything felt fine and the gauges were all ok so I just idled the rest of the way home in 3rd hi.
Everything looked and felt fine again when I got home and nothing was dripping out anywhere. I decided my thoughts on the wheel bearing were still true and went inside planning time to pull the front axle apart. The smoke was still a mystery to me that just might have been dirt on the road or something else un related to the truck.
I looked closer in the day light Tuesday after work and found the rear bottom passenger side dog bone was off its end. There were also rubbed raw spots where the inner tire had rubbed the trunion housing. That explained the smoke and the pull to the right. The rear axle was pushing the rear of the truck to the left. I probably knocked it loose with the gravel load but it wasn't until I drove it on a ruff road empty that it came off the axle.
I know this is a long write up for a simple problem. I just figured there are others like me out there that would think the same things I did when they encounter a sudden front steering pull to one side or the other and not even think about dog bones because there were no noises or vibrations to indicate something was wrong anywhere on the truck.
