Better long life head gaskets
Westech
CPL
6,104
208
cow farts, Wisconsin
thicker/newer composite gaskets... they did not come up with a updated gasket because the old ones worked great.... head gasket fail is the cause of most engine fail of the multi fuel. If you have been around the mulit for any time you will know/find this out.
southdave
ripley, oh/TDY Lordstown,Oh
i have gotton quotes for cooper gasket, I have thought maybe this the way to go. I thought they came up with this because of cost, and the thickness to span the warp or rough condition of the heads. sort of one gasket to fit all condition thing.
Recovry4x4
LLM/Member 785
1,810
GA Mountains
M35Tom has head gaskets, the newest ones for around $80. That is the best price you will likely find.
tm america
24
merrillville in
copper gaskets dont do good with weather changes and the block should be o-ringed to run them. you will find that copper gaskets will leak anti freeze at really low temps. the best gaskets a re kmetic.they hold up to turbo and supercharged cars with over 3000hp. they are always custom made you just send them one of your old gaskets and tell theem the thinkness you need and they make them to your spec. they are even reusable. they are the same gaskets they run on the top fuel funny cars-dragsters.
southdave
sorry can't or won't spell worth a crap. started researching gasket asked a buddy if he could cut one on his water table he though out copper or Al. at the time of the visit he was cutting some for cummins he suggest some thickness. I have compsite on mine now and they leak a little. found out it was exceptible.
gasket cost + 4 hour to set up Min. and the material cost haven't spoke with him since nov. figuerd I would like to get 3 set so also some karma cash was involed so??
Westech
CPL
6,104
208
With 150 Foot pounds and copper gaskets I don't think there going to fail.. just need some sort of fire ring. Its not the rings that fail its the rest of the sealing area. If you could use stock fire rings and copper I think you would have a winner.
Beerslayer
55
Tualatin, Oregon
This is why it is imperative to stick the oil and look at the coolant on EVERY cold start.
Water in the oil or oil in the water is an indication of a blown head gasket, and the truck might have run fine when it was parked and there is no way to know without looking at both.
