BIG_RED
- 0
- 0
- Winnipeg, Manitoba
Just so you know - if you go the new fuel lines route, you have to pull off the whole intake to run one to the IP. The fuel pump pushrod takes forever to line up to get the new pump in (took me 4 tries). Outside at -30*C = not fun. To put in a passenger side block heater, use the middle hole and remove the starter support bracket. Make sure the power plug on the heater clears the bracket - you may have to grind it down 1/8". I read somewhere that Wellman 070 GP's are what the military is using right now, so I used them cause i figured they must be good. I don't know if they are, all I know is mine work . Good luck!
