Jake0147
- 18
- 18
- Panton, VT
Before I throw my two cents in... The original question:What I need to know is do you have a problem getting in second gear sitting still at a stop.![]()
Yes, it is normal SOMETIMES for a transmission not to take a gear when you're at a stop. Particular a synchronized gear, but any gear really. You are trying to slide a splined collar (or some other arrangement to a similar effect) to "lock" two separate male splines together within a female splined collar. If the high spots are all lined up, it won't go.
With car and light truck transmissions, it is almost never an issue. Even with the clutch pedal down, just the air drag around the clutch plate is enough to keep the disk moving slightly, so if it's not just so, it'll pop right in in a split second that you won't even notice.
In heavier transmissions with bigger clutches, it is not uncommon to find a disk that comes to a stop very quickly IF the clutch releases enough. It is also not uncommon to find one that has an input spline sticking in the disk, a previously abused disk that still works fine, or other clutch malady that means it never really stops on it's own. (Because you can grab first gear, I doubt the latter).
So assuming the former (a stopped transmission) one quick solution is to place the shift lever in neutral, release the clutch pedal, depress the clutch pedal again, and quickly, while the input shaft is still turning, move the shift lever back into second gear. This way the synchronizer has some movement to work with, so it can synchronize (match speed and line up) the gears as it should. This is very effective with servicable transmission that has some of the "sharp" worn off the end of the splines that are to engage. The less of a point they have, the more likely it is that you will find a point where they will not engage correctly.
As for starting in second gear...
Second gear can handle all of the torque that the engine can provide. It is a weak design with the key instead of a spline, but it can hold back the engine. That is not an issue. If your clutch chatters, now we're talking about shock load, and that's another issue. But smooth application of power won't bother it.
As for the clutch, the disk that these trucks should be equipped with (and there ARE alternative bolt ins that members here have used)..., but the original clutch is not like a car or light truck clutch. They are not designed to withstand slipping. The rule of thumb is that in any given situation you need to be able to roll your foot conficently off of the clutch WITHOUT applying throttle until the clutch is released. Otherwise, you are in too high of a gear. Yes, you can start in higher gears than first, but it requires throttle input, which means that you are dissipating copious amounts of energy through the friction faces of that clutch, even if you keep the RPMs down while applying throttle. (The way you would use the organic disk in a car or pickup). But, it's a clutch... It's not the end of the world. This type should and can in the right hands last indefinately (admittadly it's a lost art, and few do anymore...) If you're ok with dropping one in every thirty, fifty, one hundred thousand miles, or if you're doing a job where excessive wear from overuse has an acceptable payoff for whatever is saved in time or effort... abuse it accordingly. It's just a clutch, there's lots more expensive things that will come up, and you do have to enjoy a deuce, otherwise there's no point.
There is one big hangup with the second gear start on the sprag actuated transfer case trucks, those without a manual activation for the front drive mechanism. That transfer case has a sprag (a "ratchet" of sorts) that eliminates driveline binding while you're driving, yet hooks in right when you need traction. These transfer cases have a forward and reverse position in high or low range, and that is activated (passively) by your gear selection in the main transmission. You can work the valves to keep it in the right place, however one slip in setting the valves and the mechanism that should prevent driveline binding actually causes (forces) driveline binding by locking the front and wheels together with a (slightly) different drive ratio. So while it can be done, it's kind of like parking a vehicle with an automatic transmission. You don't use park only when it might roll away and neutral the rest of the time, you take the extra expendature of energy and move the lever further than it has to go because it always works right. So in the case of a sprag transfer equipped truck, I would change my recommendation and say that it's worth you time to master the (gentle) release of the transmission from first gear so that second can be selected promptly. It is different (it actuates very differently inside the transmission...), feels different, times different with your extended motions because of the "deep" position of the shift lever, but it can and in this case should be mastered to the point where it is just another gear.
