- 34,012
- 1,807
- GA Mountains
Clinto, scroll down this page, has a pretty good image.
http://zenstoves.net/Supplies-Holes.htm
thats interesting that they are in the floor on the 5T and I like that idea. so they are not in the floor of the deuces but are on the dropside 5T. I might have to put a few in the floor of the deuce.The USMC Corp. ISO five ton cargo beds come standard with the " nuclear tiedowns " eight to be exact. The Tie Down Kit shown here is a MWO kit NSN 2540-00-782-1467.
I had picked up this set off ebay a year ago so I could replace my old rusty " D " rings with NOS ones. The pots I will have to sand blast. Then I will drill a drain hole in the pot to let the water dran out.
seya,
C'dub
Yeah Kenny, if anyone thinks a plasma cutter is expensive, look into one of those!Chris, what he really needs is an ironworker. Can punch holes in anything with that.
I did something similar but used bolted D-rings to catch into the supports underneath. For the center supports that are boxed in, I made tapered square washers so the nuts would seat flat. For the open channel supports, I bolted in an angle iron to stiffen the support. Ran an FEA at work that showed the open channel needed stiffening. The holes are for wrench access.Sorry but getting off the original tie down track. Went to the welding shop and had him weld 7 heavy duty D ring tiedowns in the dropside bed of my 5 ton. There are 3 down each side and one in the middle front. We also made sure to place them over bed supports. The one in the middle is in case I have to come along something into the bed. I have bent a couple of the originals in the bed of my 715, so wanted something that wasn't going anywhere.
Normally the greenlee punch is used to punch holes in electrical cabinets or panels. If you know an electrician they me even have a hydrolic punch much easier than the screw type. All you do is hole saw a 1/2" hole then install the punch and pump the handle makes a nice clean hole and you dont have to worry about a big holesaw breaking your wrists.
Here's the "whole"Greenlee setup, brand new and it's only $1700.00 !!!
I bought mine at a pawn shop ($400.00)
most tool rental places have them as well.
