eldgenb
- 1
- 16
- Spokane WA
don't let anyone scare you out of welding the sprag, if you were running detroits in every axle or welded the spiders in the diff's than it would be a problem, if you weld the sprag and leave the diffs alone its like running a regular truck in 4x4 everywhere you go. But with 230 hp you are not going to be breaking those 2" axle shafts anytime soon and with the terrain you are on you are not going to have any advanced tire wear just three axle's engaged all the time. It sounds like the best, most aggressive, and most cost effective of all of your options. I have done it many times and I think there is some how to in this forum as well. Once you open the case it will be painfully obvious what you need to weld.
