haggis6145
- 0
- 0
- Toronto, Ontario
Can anybody confirm that the radiator for the M1009 is the same for the M1008/M1028?
Just got mine cleaned out (pulled one of the side tanks off and cleaned each tube) and fixed for $70 and it looks as good as new. Might just want to do that.Thanks guys. My M1028 rad has a small leak, gotta replace it at some point. But...they want $800 up here. So, I figured I'd wait for a deal. There is a new M1009 rad for sale on eBay that will probably be a lot less. Any thoughts on the exchange?
Yes they are. I got lucky and found an almost new one at a swap meet for $30.00. One thing I know is the 1982 civi trucks with the 6.2 used different fittings for the oil cooler in the radiator. Not sure about 1983. As long as you match up the year you should be ok.Are they also the same as the civvy radiators?
Where did you get this info from? Any supporting evidence? Thank you for posting but to help other people please list your sources.Radiators in the Blazers are smaller than in the Pickups
