a68cudas
- 0
- 0
- Brookfield, Ohio
I need to find a rim for m1009 so i can have a spare. mine didnt come with one
where can i look to find one of these at?
what would be the visually correct version? any years or other chevy gm models that had same rims as m1009?If you aren't worried about being visually correct any 1/2 ton 4X4 from 73 to 87 (up to 91 on Blazers and 1/2 ton Suburbans) should work. The newer 1/2 tons have the same bolt pattern but the center hole is smaller, the lug holes are larger, and the offset is different. I would avoid those. If you were closer I have a bunch here. Good luck.
The "correct" wheel is kind of an odd ball. It is just a plain wheel but it is 8" wide. Most plain wheels of that era are only 7" wide.what would be the visually correct version? any years or other chevy gm models that had same rims as m1009?
Not in this part of the country. Do I need to dig up pics ?The CUCV wheel is the rally wheel.
I would rather see a M1009 with the right wheel also. Not a rally wheel. The pictures below show rally wheels without trim and with. The M1009 did not have these from the factory.I will go with AJM on this one.... just plain steelies.
