Deuce brakes
JeremyB
Lake Mary , FLA
Hello all,I just picked up another deuce and alas it has NO brakes. The air pressure builds up,but no stopping. Do any of you gentlemen have a starting point to go from?:cookoo:
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
Does it have fluid? Fill it and bleed, look for a leak, and read the TM.:wink:
JAYHAWK 1962
tijeras, nm
Air /hydraulic brakes. If the air is working and the brakes aren't. I would tend to think it is a hydraulic problem. Same recommendations as others. You might want to checfk for blockage in the brake line coming from the master cylinder.
Mitymac
Red Lake Falls, MN.
Fill with fluid, (dot 5) pump the brakes till you get some peddle. Refill. Now have someone pump up the brakes and hold peddle down. Go to each wheel and bleed of air and close value, pump up again and bleed till air bubbles stop. Important keep fluid full and the peddle cannot be let off while bleed valve is open at your wheel. Your peddle should continue to get harder to push sooner. If you did get brakes but the truck pulls when stoping you still have air at wheels opposite of pull start with them again. When working under check for leaks at cylinder and coming out of brake drums. If that works check later drums and cylinder and lines and replace bad parts. Good luck!
89m1007
great falls montana
i have an air leak on mine, there is a line going on to the dash that i bent over and it built up 150 psi and the line popped
open again what is this line for?
bigmike
355
Dixon CA.
do a search for "power bleeder". Several members built a power bleeder out of a garden sprayer. I copied it and it worked great. The reason I recommend this is because it took quite a bit of fluid to get the rest of the air out of my brake lines. I had the same problem and it was taking forever to bleed them the old school way.
