dieselfuelonly
- 1
- 0
- Chapel Hill, NC & Greenville, NC
Gonna go put a deposit on a Deuce I recently looked at today, and then go pick it up on Tuesday. I can't wait . Its about 35 miles away (takes about an hour mostly because of traffic)
I have a few questions - here goes:
1. The owner had some gasoline in the tank - not sure if it was a gas/oil or gas/diesel mix. Since I don't want to attempt to maneuver through a smaller gas station on my first try, I was going to take some diesel fuel with me in some cans. Would it be OK to put diesel fuel in the tank if there was already a gas/oil mix in there?
2. Lets say I have a flat on the way home. I know there are some dangers when working with these, especially when changing the actual tire off the rim. Does this danger of rim pieces turning into projectiles exist when removing the flat tire/wheel and putting on the spare?
3. The upper radiator hose that is above what I think is the alternator (or is it a generator on these trucks) on the right side is leaking and I would like to take a piece with me and some hose clamps just in case. Can anyone tell me what size radiator hose I need to get?
Thanks for the advice and any other tips you may have. Can't wait to get her home.
