go to my website, lots of pics of a GRC-122 minus the TTYs, but they are on the way.
Can't answer for Richard, but before the DRMOs got all uptight you could walk over to the scrap side from the GL side and talk to the guys with the scrap contract and make a deal or two. The way it generally worked was that whomever had the scrap contract had to keep the stuff piled in their area of the base moving (i.e. you couldn't let it accumulate), but other than that the definition of 'scrapped' seemed to vary, as did the procedure for its disposal. Once I saw literally stacks of brand new mod tent center sections, tan FMTV tops still in the boxes, brand-new tow bar adapters, Bose combat headsets and all sorts of other crap in the scrapyard - where GL had nothing but triwalls of garbage on their shelves for four sales in a row (typically things like WIDGET, BRASS, QTY 1400, PN 9M31403, UOC NSN 2112-01-246-2183 FLEET OILER USS BILGEWATER..))Great page!
That was a tremendous find!
When you said that you rescued it from scrap at DRMO...
Did you win an auction, or did/do you have some sort of other arrangement?
Thanks
Here is my AN/GRC-142(A/C). It was an "A" model but upgraded TTY makes it sort of a hybrid. Common military conversion when the UGC-74 became available so I swapped out the TT-98. 100% complete and operating. I use it on AC power, the 28 volt generator trailer or the vehicle power. I had to repair most everything in there and find some missing parts. Still need to repair the chair! In a following post, I'll show my latest acquisition.Anybody here have a restored RATT Rig?
I have recently acquired an M1028 and will be looking for an S-250 Shelter for the rear and am looking for inspiration pics...
Thanks
Near impossible. I think acetone is about the best solvent I have tried. I have all "B" model UGC-74's and they don't have that problem. However, ribbons are the problem with the "B" & "C". If you find a "B" with a cartridge, you can replace the ribbon in it.I also recived a UGC-74A V3, however, the common problem of the paper rollers, they melt at room tempreture so the gray rubber is now a gooy liquid throughout the machine, and the paper is glued in with it. Should be fun to try and clean that mess up.
