MEP018A selector switch
cranetruck
75
Meadows of Dan, Virginia
Starting to clean up the 10kw genset and could use some parts. The "Current Selector" switch is most acute, but is there a "parts" MEP018A out there for general cannibalization (found nothing in the classifieds)? The tubular frame is badly bent on mine as well.
liftman
Central RI
I have been looking for some new knobs, but my switch is ok. I had done some research on the knob availability and found that newark.com seemed to be the best resource.
Maybe they can help with the switch as well if you know the configuration. They seem to have a lot of items that will work.
cranetruck
75
Part number should be MS91528-1K2B.
If someone has a mep018a in any condition, as long as it's not physically damaged, I may be able to find something to trade for it...
298
Olean Ny
Looked in IHS and the Gov't cost is listed at $2.01.... so the $4.50 isn't all that far off on the markups I've seen on some of the older replacement parts I've had quoted.
