blybrook
- 1
- 18
- Fairbanks, AK
I know there are several threads about flipping a lunette. Most have great details, but here's how I have found to get it flipped in about 20 minutes without a torch, driving down a bumpy back road or beating the living tar out of it with a BFH.
Tools needed:
1-1/2" box wrench
Vise-grips
Screwdriver
Hi-Lift Jack
Length of Chain w/ 2T Clevis for Jack End (3/8" diameter clevis); can substitute chain for a twisted or straight clevis as I did
8lb Sledgehammer
3lb Mallet / Deadblow Hammer
Cheater bar for box wrench (mine is a chain binder tool from a Semi Supply Shop)
Steps:
1. Remove Cotter Pin & loosen the nut to the end of the threads (small mallet, screwdriver, vise-grips & wrench with cheater bar are utilized here)
2. Remove bottom plate of hi-lift jack and attach clevis to jack
3. Attach chain around the front grip / lifting lug of the trailer (above lunette) and to hi-lift jack (or utilize another clevis)
4. Position jack to "lift" the eye away from the frame (see photo) & put as much pressure on eye as possible with jack (may have to readjust after the first wack of the BFH)
5. Hit the eye with the sledgehammer on each side 2 to 3 times; should pop out within 6 hits (total)
6. Apply some grease and reinstall in desired position
Should take 20 minutes or less to complete the operation if you are quick with the wrench.
Pictures are attached of the tools I utilized and the connection to the trailer. The lunette shown was severely rusted in position and someone busted out the cotter pin and a punch in the hole trying to flip it before it went to GL. That hole is 3/16" diameter if you ever want to clear it with a drill bit. It took me about 2 hours to get to the point where I could start getting the nut removed.
Yes, I do know that I bent the front handle some, if I had gone to a chain around the frame to the jack instead, I doubt I would have bent anything.\
Hope this helps someone with their lunette flip operation with all of the trailers that seem to be going through GL recently (that is if they are not kept stock to work with the Deuce)
Tools needed:
1-1/2" box wrench
Vise-grips
Screwdriver
Hi-Lift Jack
8lb Sledgehammer
Steps:
