southpolie
- 0
- 1
- santa barbara, ca
Hi All,
New member here and new owner of M1009. Bought the truck two days ago and drove home about 40 miles with no difficulties. Stopped twice and restarted without trouble.
Tried to start yesterday morning. Turns over but won't start. Tried about 10 times, 10-15 seconds of cranking followed by a minute wait for starter to cool. Accelerator depressed half, full, or not at all. Suspecting fuel problem since little or no exhaust.
This morning pulled the pink solenoid wire and had a friend crank it while I bled the fuel filter. Lots of fuel right away. Still wont start. I can hear the solenoid click when I pull the pink wire with ignition on.
I bought a new fuel filter but have not replaced it yet. If I get fuel flow from the bleed while cranking, does that mean the filter if ok? Or is that pre-filtered fuel?
I am in Santa Barbara so temps are running in the 70s now. The truck is parked in my driveway with the front slightly inclined.
Looking for advice on what to try next. Saw some posts referencing WD40. Can that be sprayed in to air cleaner as a starting aid? Or on to glow plugs?
Jerry
Jerry
