panzerjunky
- 0
- 0
- san diego ca
Hello Gents
I have searched the posts but could'nt find exact answers to a couple questions
1. In reading the posts it was brought up several time about oiling the airpack my airpack looks fairly new but I want to get this on my pm list so my question as I have nothing to compare by how do I know if I have a short pack or long pack from the posts i gather the long pack has an oil port at the rear and the short pack does not would someone be so kind as to post a pic of where to put the oil in each type of pack ?
I am guessing as to the newness of my pac it is the short style in the daylight I will check for the rear plug.
2. I have a squealing from the brakes when I apply them when the pedal is depressed lightly they will howl when I push harder the howling slows and then as the brakes warm up ( repeated stopping ) the noise almost completly goes away. is this normal????
I am planning on replacing all the brake shoes and rebuilding the wheel cylinders this summer so I am trying to round up all the parts if the above noted noise is a bad issue I will do the brakes sooner than later.
The truck does stop fine at this time.
3. when I do the brakes should I replace or try to rebuild the master cylinder
and lastly and most important what tm or tms if the step by step for master cylinder repair or replacement, brake shoe replacement and most importantly the tm that shows the complete proper bleed down procedure for the brake system on these trucks
