glcaines
- 2,593
- Hiawassee, Georgia
Well, I finally got my transfer switch installed. I purchased a 400-amp Square D four pole manual transfer switch on E-bay, new in the box for a really good price. I mounted it myself, directly under the meter box, a very difficult job for one person with the weight around 300 Lbs. An electrician wanted $1500.00 to wire it in after I had already mounted it and had also run the conduit, so I wired it in myself to save money. The meter box was a Siemens with the meter on the left and the two disconnects on the right. I have 400-amp service, 320-amp meter, which feeds two separate 200-amp panels. I took out a permit for the electric work, had EMC cut off the power and completed the wiring myself. I removed the meter, and then removed the four 4ø cables from the meter to the two disconnects. I ran 4 new 4ø cables from the meter base to the transfer switch and 4 new 4ø cables from the transfer switch back up to the existing disconnects. It was a royal pain working with the 4ø cable and all of the tight bends involved. Since the transfer switch was connected to the service box via PVC conduit, I also ran a ground wire to the transfer switch to ground it. I had previously run 2-inch conduit 125 feet from the transfer switch around the garage and terminated into a box with a pin and sleeve connector with 2ø cable. I had to bury the conduit 18 inches deep and navigate pipes, drains, tree roots and go under a sidewalk. I plug an SO cable into the connector from my trailer-mounted MEP-003A. I may get a second GenSet for a permanent installation later. My current setup is a whole-house installation, and the MEP-003A is strong enough to handle my geothermal head pump, etc. without coming anywhere close to overloading the generator. I had labels engraved that indicate the switch positions on the transfer switch and also have directions on how to hook up and start the GenSet, in the event it is needed and I am elsewhere.
I passed both the County and EMC inspections without difficulty, although I had to do some convincing to get EMC and the county inspector to agree to let me do the work without any electricians involved. Although I did this work myself, I would not recommend others doing this without experience.
