jager07m1008
- 0
- 0
- danville pa
ok lets start by from what I can see the wiring on this truck is now what it is suppose to be my problem is that i can not hook up the red/white wire to the right alternator. if i do so i have sparks at the last battery terminal that i hook up and not little sparks. the left alter. is hooked up with red to engine wiring harness block and black to intake ground. then the tiny brown wire to the wire harness. I am not sure what that wire does.. right alter. red to positive teminal block. red and white i can not hook up . i have tried to replace gen # 2 light and i still get no light when starting i took dash apart today and have 24 volts at light bulb connection i did not test the generator #2 relay not sure how and also not sure if the one that is there is the correct one. i have been working at this for 2 weeks now and one step from selling the rocket. if anyone wants to give me their phone number so i can talk to a english speaking human I would greatly appricate that. thank you ahead of time. also if I do not respond right away i may be trying to figure something out THANK YOU
