Looks like it's working now. I called out on my co-workers, a prior Enlisted Officer who used to work on deuces, and he did what Warthog did and used a jumper wire on the starter relay and it fired right up. Should I look into replacing anything at this point?
Glad to hear the truck is running. You can send me a $5 foot long!!!!
Your starter switch may be bad or the circuit is bad.
Time to breakout the ohm meter and check the circuit.
