Mission accomplished
gunboy1656
22
Beaver Falls, PA
Today I set out with a goal.....to replace a rear axle seal.
This was going to be the first time I EVER did one. I was supposed to have a friend come over who knew how to do it. but we could never get the times to match to work on it. So I learned as much as I could from all the posts and the limited info in the TM's about doing in.
So this morning my dad came over to give moral support, and help me get the wheels off, and away we went. took a little longer then we thought since we had to run out for some parts. Took us about 2 hours (including finding the stuff we need).
I want to thank all who posted about doing the job, it was a GREAT help.
Unfortunately there are no pics, as I was too greasy and oily to take any. Now I am confident I can do the rest.
gunboy1656
22
Beaver Falls, PA
It was a good day. Learned something new.
Took it out for a trip; no leaks, fluid levels still good. Even the lug nuts never loosened.
Only downfall was a little sunburn.
DieselBob
15
Arnold Maryland
Good to hear all went well. Did you use cork wedges or RTV in the spindle key way. I have a couple items to get and then I'm pulling all the hubs for bearing repack and brake inspection.
wb1895
17
Lexington NC
Where did you get the axle seal and how much did it cost....(if you dont mind me asking) I have a leaky middle axle seal and am in need of parts.
123
Ferris, Tx
Wow, that's not bad for your first time I would suspect. My rears are all leak free so far.
I have both front inners leaking. I'm hoping it's just a plugged up vent but won't know till I get under there.
If the vent is clear, I'll be researching a bunch myself and ordering seals and boots for the deep dive.
Wish me luck...I'm going in!
gunboy1656
22
Beaver Falls, PA
The vent was one of the first things I tried. Didn't want to make more work then I needed to, but the vent allowed air to pass...so, it was time to get messy.
Just looking at the truck, it looks hard. Actually doing it, it goes quick. And I was not using air tools, just a standard lug wrench (not even geared), pliers, 3" socket
