Has any one had to grind on their starter shim to get it to fit? mine is hitting the starter housing and only allowing one hole to line up...I had to temp just leave the one side moved forward so it didnt block the bolt from going thru, i gotta grind out a lil of the shim to make it right sooner rather than later!!!!
