jimm1009
- 71
- 48
- Louisville, KY
The dash for the gasser had a narrower removable panel due to not originally having a tachometer.
I think that they made an entirely new panel during conversion and centered the tach and speedometer as best they could at the top and then with the remaining gages grouped together below.
Perhaps someone else knows for sure but the gasser panel probably had the speedometer centered like an old jeep and therefore could not be reused during conversion.
I understand that the left front fender had to be changed out due to a requirement for increased width in the engine bay but this is 4th hand information too.
Having the registration number and the serial number both will help an owner find out the details of their truck.
The s/n is stamped on t he frame in the left wheel well just to the rear of the reinforcement plate for the steering box or just in front of the upper shock mount. You may have to use a steel brush and some paint stripper to find the numbers. Grinding or power brushing can actually damage the numbers. The frame heat treat date may also be adjacent to the numbers with will help narrow down or prove the year of manufacture.
jimm1009
jimm1009
