- 359
- 26
- 28
- Burdett NY
Followed all directions in TM on bleeding brake system. When I go to pump the break away lever it is loose, can feel the spring move around for the first 2 notches on leaf spring. I am able to get good pressure on the break away lever except for the begining, also no air all brake fluild. Any thoughts on what needs to be replaced. The Lunette has good travel and back pressure from the brake fluid as well. I have another trailer that the brakes work great on and I don't have that freeplay in the beginig of the break away lever.?????????? Is this about the shock or the spring hardware????
