O.D. Fever
- 2
- 0
- Howard City, Mi.
OK I searched but could find no info. The load holding brake on the 10 ton winch was locked up by rust causing the shear pin to snap. Pulled the cover and removed the adjustment bolt and freed the shoe, cleand it all up. The question is about the spring or springs. My spring came out in many pieces. Are there 1 spring or two? does one go in between the lugs on the shoe and another on the outside of the shoe lug? Or is there only one spring, does it go between the lugs of the shoe or against the housing and shoe. If I had to guess there must be 2 springs.. Any help would be great, a picture would be better. Thanks Joe
