hardtime
- 0
- 0
- Bailey, Co.
Got back from a trip and wife had a 5-ton winch in the back of the truck, SWEET!!! She hacked in my comp. and found the info to a S.S member and picked it up. Dave had everything all in order for her with all bits and pieces.
Total time was about 2 days. Gathered up all new bolts and engine hoist ect.
Removed transmission cover and flushed out trans real good with clean diesel.
Cleaned up PTO and clecked all linkage and forks.
Made new gaskets/shims and preped all mating surfaces.
cleaned treads and studs and siliconed studs into trans case
Installed PTO and checked gear lash. The first time was way to loose and the second time to tight...three times a charm picking that little chunk up and down and it was time to prep gaskets and go for it.
Removing front bumper was a bit of a whore but came off with out the tourch.
cleaned pieces and bolted all plates together.
some of the winch nuts where missing so we welded new ones in place and dropped winch in place.
cleaned and lubed prop. shaft and installed.
removed pass. seat and rear hump cover and lubed and installed lever and linkage.
Filled trans with new juice and tested her out.
the only thing we can not figure what happened to the truck that this came off of is that both outer bumper plates at the 3rd hole back are cracked around bolt holes and slightly bent outward. We pulled them back and welded then and installed bumper.
All in all it went really well...the hardest part was picking up the "lead" PTO by my self 9 times to check for proper lash. Thanks Dave!!!
