army70deuce
- 3
- 18
- Anderson, SC
I've read all the power steering posts and definitely want to add power steering to my M35A2. I've also read the Winch posts and want to change my stock winch to being driven by hydraulics. So here's my question.
Are there any issues I'm not seeing with running the winch and the power steering off of the same pump? I know I need a large reservoir to help with cooling. What size pump would you recommend to run both, what capacities should I be looking at? I'm assuming a standard power steering pump for a M35A3 would not be enough for both, not sure on the 5-ton.
As always, thank you for your help and all thoughts and opinions are greatly appreciated.
