Oldsouthernboy
- 0
- 0
- Jacksonville, al
The power steering pump rear brackets are hard to find, both the small bracket from the pump stud and the bracket from the engine block the pump stud fits to. Also the power steering bracket it self is hard to find. IF working on the power steering pump make sure you use the right pully puller, if you bugger up the pully you will have fun finding another pully.
