Csm Davis
- 394
- 83
- Hattiesburg, Mississippi
Basically if it is a fluid and it will burn you can run it to some degree I have run one on melted butter and margarine!
I'm not who you were asking, but until you get a reply here's a little food for thought, mixed with a little opinion on the subject...Afternoon Emmado22 based upon what I read in this thread you seem very knowledgable on Fuels for the 35. Here is my question. On a data plate on my truck it states to NOT use any type of AVIATION gasoline! OK Running ANY type of gasoline in a diesel engine usually resutls in destruction of engine, I totally understand that but WHY would a gasoline of a usually higher octane rating be forbiden in this engine? The higher octane rating is made to run in higher compression engines because of its ability to reduce Pre-ignition possibilities in a gasoline engine but can you explain to me WHY this type of higher octane gasoline is Forbiden from being used in a Deuce with a LDT 465 C, I am just trying to learn WHY.
Thanks Emmado22
Karl
A diesel engine is generally considered to be a compression ignition engine (as opposed to spark, hot bulb, etc). The multi, being a compression ignition engine, is still a diesel.First, the Multi-Fuel engine is NOT a diesel engine. .
Welcome to the machine. Would you please put and S behind the word question in your postI have been thinking of buying a Duce with the multi fuel engine.I have been told by the owner that he runs waste motor oil,and used transmission fluid.My question is how efficiently would it run on these fuels,and can I run them straight or do I have to cut them with desiel or gas?If so what precentige do I use?Also could a hydrogen booster be used?Or could the engine be converted to run from straight hudrogen?What are the efects on fuel milage from doing this?How much does bobbing effect milage?
Thanks for sticking your neck out Jake!I'm not who you were asking, but until you get a reply here's a little food for thought, mixed with a little opinion on the subject...
First, the Multi-Fuel engine is NOT a diesel engine. Very much similar, based on one in fact, but not the same. Your first satisfaction will come from digging into the MAN Hypercycle process.......
There are many posts specifically on this topic via search but when you say "fastest and cheapest" way its usually one or the other. Cheapest I've seen is letting it heat up in the sun and squeezing it through a pair of jeans (YMMV). Fastest is probably a centrifuge plus it gets water out. But you can work up anything in between. I'm sure more guys will chime in.Their have been some post about using used moter oil and flitering realy well. My question is how do you fliter used moter oil? What is that fastest and cheepest way to go about doing that?
Beware waste motor oil that has not been personally processed. A member here used some that was filtered by the provider, but still had anti-freeze in it, and it ruined the engine during a summer trip with his wife across New Mexico. During the attempt to repair and get the truck back on the road, the gentleman had a very serious heat stroke out there. This is nothing to fool around with.From what I've been told, yes, but you must filter it well...
