el_magico
- 1
- 0
- Thornton, CO
So I have been searching for a receiver platform for the deuce that was to my liking and still affordable. Couldn't really find one that I liked so I designed one so I could make it happen. Some of the things I wanted were to have it tucked just under the pintle, high enough to maintain the clearance but not too high that I would need a 20" drop receiver. So, I split the difference. The hitch drops down 9.5" from the bottom of the frame, leaving need for a 10-12" drop receiver. This is what I came up with.
I ran an analysis in SW also and these are the numbers I came up with (this is including a 12" SOLID drop receiver)
Tongue Weight: 4000lbs
Towing: 30,000lbs
Safety Factor: 6
My question to everyone here is: Would any of you be interested in a platform like this?
Additional info: The platform is designed to be mounted to the frame using 6 3/4" grade 8 bolts. To me this is the only real con about it, having to drill 6 3/4" holes through the deuce's 5/16" thick frame!
Towing: 30,000lbs
Safety Factor: 6
