- 1,177
- 26
- 0
- Northern Minnesota
I've got some great news to share in fact it's so good I held off reporting on it until I could triple check my mileage numbers. My mileage readings have been too good to be sound true so I wanted to make one more check --- which I just finished doing tonight --- before posting this thread. My mileage reading tonight equated to 18.28 MPG!
Here is what's going on:
A few weeks ago I installed a Holly/Weber 32/36 model 5200 two-barrel progressive (mechanical) linkage carberutor on my M37 (The Pumpkin). After purchasing a Haynes manual for the C/W 5200 and spending a weekend reading and another few days experimenting and swapping jets I've got a winning combination.
I've got "LOTS" more low end torque and when you step down on the accelerator and open the second barrel the old truck runs like a scared deer. My first fuel mileage tests were made when I was still experimenting with the low idle jets so I was only geting around 12 MPG. As the jetting got better/closer the mileage started to improve. It went from 12 to 14 to 16 and now, tonight I got 18-1/4 MPG.
To check the fuel level I'm gently shaking the truck from side to side while fueling to remove the air bubbles from the tank and filling to the bottom of the large filler area in the tank inlet. In doing this I can get an accurate consumption rate on an approminate 150 to 200 mile test.
This last test was made running @ 2500 RPM (red-line) most of the time.
My truck has a fresh 230 engine that pulls 489 gears. The tires are 36" Denman Coyotes 305/85R16 with spin out hubs. Outside of the head being milled .030 and a civilian distributor installed the engine is stock. Some pictures are attached.
Langdon's Stove-Bold Six sells the carb as a kit but I found you will have to do some re-jetting. Here is what I am running for jets --- I'm not finished experimenting yet.
Primary Idle "100"
Secondary Idle "050"
Primary Main Fuel "330"
Primary Main Air Bleed "180"
Secondary Main Fuel "132"
Secondary Main Air Bleed "195"
I feel the Primary and Secondary Idle jest are as close as I can get them. The Primary and Secondary Main Fuel and Air Bleeds "MAY" be able to be improved.
I just recently learned that at mid-throttle a 14-1/2 to 16-1/2 air to fuel ratio is optimum. At full throttle about 12 to 1 is a good rule of thumb.
If you decide to play around with one of these units keep an eye on your plugs so you don't burn a piston.
More to follow.
Primary Idle "100"
More to follow.
