ranchhopper
- 139
- 63
- south elgin illinois
I finally got some of the exhaust fabbed together out of the turbo so I could get the cab mounted. The engine was shoehorned in as was the exhaust not much room anywhere. After the exhaust was run I dropped the cab on the risers everything fit pretty well just a bit of grinding here and there. I put the HEMTT wheels and 1400-20s on so I could get the power steering gear mounted went pretty fast no clearance issues there. I am welding together a dog house to fit over the exhaust system in the cab it will be kinda like a van has inside. I am going to put a hood scoop near the cowl so it vents cool air down between the cab and turbo to push out the heat somewhat.
