- 1,926
- 30
- 48
- Irmo, South Carolina
Another vote for install photos! Also, please describe the Evap unit and where you got it!
Rick
Rick
http://www.steelsoldiers.com/122016-post17.htmlDo tell ? Did I miss something ?
OK, there are tons of cheap SD508's on ebay, I assume you are using a 24V clutch? The 24V units are far less common.new SD508 compressor, $155
new condenser, $90
new evaporator, $135
2 belts, $34
hose fittings, $17
Considering there are a lot of clutches out there on the front of 508's, how do you know which one will clear? Do you have a part # or a spec? With my luck, I'll buy one with a clutch that sticks out 1/8" more than yours.i have the template for the rear mount, the 2 others are just 1/4" by 1 1/4" cold rolled stock. the fan only clears the compresor shaft by 1/16"!! but anything is enough........
M-35tom, can't thank you enough for posting up a thread about this. I am ordering my 508 compressor now. I was originally going with a "nostalgic air" kit but looks like this will be a better route.clinto and others, this is what i found today on ebay. search for 'new universal sanden style sd508', also 'universal underdash evaporator minibus' and 'universal condenser 14 x 24' the fitting size should work out right and the minibus evap is more btu than i used, but i would go with it next time. (22,220 btu versus 13,000)
i ran the whole thing on 12 volts since the evap is electronic and 12v
tom
