Well I worked on my M1009 for over 8 hours today in the hot Texas sun.
Got my lights working, some one installed a melted looking fuse.
I am starting to suspect someone melted it with a lighter and then inserted it on purpose, and put my glow plug controller card in backwards to give the appearance that the truck was not operable. I replaced the fuse and everything works just fine.
Pulled the seats and radio rack out. Then I yanked that nasty plastic mat out and found a ton of sand, a grenade launching blank, air soft pellets, pieces of paper with numbers on it, and some officer’s rank insignia.
Vacuumed up the sand and got a good look at the condition of the floor boards. The front passenger side floorboard will need to be replaced. Several spots behind the passenger seat will need to be patched up and the passenger side running board will need to be replaced because it is rusted through in one spot.
part 2 below
part 2 below
