.. sort of. I had the constant leak I heard otheres talk about here. I have the new styly air pack that apparently there is no rebuild kit for yet so I disassembled the air side of it. I took out the circlip and sure enough the rubber disk with the metal in it was swollen and busted. I used a pick to carefully remove the corrosion from the metal disc without tearing the rubber more. I filled it with black rtv in the pocket and squeezed out the excess. I installed the disc again with the other side facing out to get a good seal. It worked! At least for now I am building 90 psi and holding air long after shutdown. Sorr, I didn't take pics, it happened fast. I took the whole unit to NAPA first and they said they had never seen one.
