New toolbox on M818
MyothersanM1
19K M1 Armor Crewman
427
68
Culver City, CA
My brother and I removed Hannibal's left fuel tank and installed a Buyers 36"X18"X18" toolbox. This is the one I bought...
Buyers Black Steel Underbody Toolbox with Black Aluminum Diamond Tread Door - Truck Tool Boxes at Tool Boxes Direct
I believe I originally found the website here on SS. It fits like a glove. We bolted it to the existing fuel tank brackets. I'm going to leave it black. It matches the tires.
On another note...I have ordered a set of composite headache racks, troop seats and a front rack from Stephan Wood Products. They are en route as we speak. More on this later.
MyothersanM1
427
68
Culver City, CA
Definitely looks good, nice that it uses the existing brackets.
After a few passes with the pneumatic grinding wheel and wire wheel, We laid a fresh coat of primer to inhibit any rust from forming under the box. We shimmed out the fuel tank brackets to about 9" to give the mounting a little more rigidity. We drilled four 1/2" holes in the brackets and the toolbox floor. Using four 1/2" X 1 1/2" bolts, washers, lock washers, hex nuts and a little silicone caulk for sealing, we secured the box and the job was done.
I am thinking of mounting my pioneer tool rack on top and modifying the fuel tank straps for a little more support.
