The government would rather carry a truck loaded with barrels of GL5 SAE85W90 than a truck loaded with a little of this, and a little of that. They chose one single oil to simplify their supply line, but you use so little oil that there is no reason for you to do so.
The transmission manufacturer specified SAE50 motor oil. The transmission definitely does not need the extreme pressure (EP) additives that are needed to keep hypoid and worm gears alive in differentials. In fact, some of the EP additives contain sulfur products that will actually harm the brass and bronze bearing parts in the transmission. That is why the GL1 yellow metal safe requirement is in place.
What I intend to do when it is time to change my transmission oil is to put a nice SAE50 motor oil in it. Stinky oils (hypoid) belong in the differentials, not the transmissions.
One other thing to note: There are multiple oil standards in the SAE numbering system. SAE 90 gear oil is about the same viscosity (thickness) as SAE50 motor oil.
-Chuck
-Chuck
