AndrewH
- 1
- 18
- Boyne City MI
I just changed the HH on my Deuce. It started right up and ran. I did notice some hunting at idle. What I really noticed was smoke at idle. When I drove it I had no power. Had to come up the driveway in low 1st. Normally an easy high 2nd hill. I have removed the shut down and the advance cover and checked timing marks. When the damper is on the marked line the advance lines up in the window and the red'scribed HH tooth lines up. I replaced the HH because my old one leaked around one of the allen haed scres on it. The truck ran fine. I'm searching here but have not yet found a similar issue. The manual says to check timing and fuel rate. I do not have a flow bench handy so I'm looking for input. Thanks Andrew
