srodocker
- 68
- 48
- Lacey, Washington
thats kick ass. if i ever get one i want that lol
Me too. I'm going to build a spare-tire mount on the back left-side of the M109 box. Not planning on actually carrying a tire there very often, but want to have the option. It's going to be mounted to the 2" x .120-wall tubular roofrack with tubes that extend downwards to the bottom of the box. Might put the spare-tire mount on pivots, like a swingaway tire carrier, so that you can still open the small door when a tire is mounted. But seeing as there won't be a tire on there very often, I might just keep it simple and make a solid mount. I've got a cheap-o HF hoist, and I'll just need to make a stub-mount on the top of the box at that corner. Only other place I can think of would be on top of the cab, on some type of platform (cabover rack like I built, or a gun-ring mount, etc.).Hi Jess, I picked up a few 50 Gallon deuce fuel tanks up at Brad's place. I'm going to mount one of those tanks where the spare tire carrier currently resides.
That would work, except the towbar couldn't be raised to be vertical because it would hit the bed/box. Would be kinda cool if you made a custom swing-down tire carrier that was mounted to those shackle-mounts though. Would probably need to remove the bumperettes, but that would actually work pretty well. Use a little hand-winch to raise/lower the whole assembly...
That's exactly what I was thinking, except you could use the existing shackle mounts as pivot points and just make the tire carrier offset to one side.this is a carrier on a GAZ-66, it folds down.
Looks VERY cool, but those M109 boxes aren't very big to start with and there's no way I could give up any more interior space (which a 43" tire would eat up quite a bit of).I was thinking something like the way the spare is mounted on the WC54, or in an inner compartment with an access door on the outside like some utility body rigs have.
I got one of those that I'm going to mount on the tongue of the M103A3 trailer that I'm going to be towing behind Mah Deuce.you can move your bed / box a bit back and mount a carrier like this :
http://www.steelsoldiers.com/attach...-my-new-m35-tractor-trailer-robstruck-007.jpg
on the right side is some space left for a nice toolbox.....
Not sure I'm following you, but if I am, seems to me that would have to put an awful side-load on a stabilizer jack. Why not just use a small electric or manual winch?Mount an RV electic stablizer jack to the rear door with an extended leg with the plate from your spare attached - push the button lower the leg - bolt on the spare - reaise it up into position.
I am going to try the Gaz way later this year. I asked Robo McDuff to try and get some close ups one that is not to far away from him. I was almost going to start another thread but used search and found this one. Here's another Gaz rear shot.this is a carrier on a GAZ-66, it folds down.
