deuce_09
- 3
- 18
- san antonio/TX.
I was just wondering if you can mount up 2 PTO's to a deuce. I'm building up some cash for another deuce and I'd like a rear winch.
the pipe line truck used the tc pto for the rear winch, the line trucks had the auger/pole setterthey also had some that mount to the transmission PTO to run the winch on the pipeline trucks. Pipeline trucks also had the t-case PTO for the rear auger.
I think truck you are thinking of would be One of the telephone trucks, the pipeline had it's winch chain driven off of the t-case pro. Which by the way more robust than the pto for the front mounted winchthey also had some that mount to the transmission PTO to run the winch on the pipeline trucks. Pipeline trucks also had the t-case PTO for the rear auger.
I've looked at that cover on the PTO and wondered about that. Never accually seen it done though. I wonder if the gears would line up?Also, the standard winch PTO has a 6 bolt cover that can be removed and another PTO piggy backed to it. I don't know of anyone that has done it, but it can be done.
thats how the wrecker wasalso if you could find one (doubtful) the civilian trans had a pto cover on both sides.
tom
Look at the two pics attached and you will know the answer.....I've looked at that cover on the PTO and wondered about that. Never accually seen it done though. I wonder if the gears would line up?
The problem I see with running a rear winch off of a trans PTO accessory drive is that you'd only have one speed in one direction. I think a t-case PTO would be much better for a rear winch (5 forward speeds and one reverse).
