1978davidw
- 0
- 6
- unicoi tn
I am fixing to redo all my vents and get rid of all the bobblehead vents and replace them with a single system all hooked to a poly line with all the axles and the tc and tranny teed into it as well. My question is some people on here are doing this already and putting the inlet in the air cleaner housing on the pre filter side. Wouldnt it be a little bit more effective to put the line in the post filter side of the air intake system? My thinking is you can get some albeit small amount of vacuum that way. My only concearn is the shaft that is in the tranny that runs into the bellhousing. Its unsealed and i assume that it is lubed just by tranfer of oil since it is above the oil level in the tranny. Would putting a small vacumm on the system prevent this point from getting lube then while driving?
