FireFighterHill
Banned
- 1,540
- 62
- 0
- Riyadh, Saudi Arabia
Finally got all the parts together to get it running. NOS Carb and new batts. Didn't have to many problems though there was a few. The fuel lines pretty much all need replaced. They all seem dried out and brittle. Trying to prime it I found the line that runs to the jerry can clogged so I had to set up a temp setup with a short length of fuel line I had laying around and a primmer bulb.
I also found that the flexible line that runs up to the carb from the fuel selector has rubbed a hole into the tube that runs from the crank case to the head. Any suggestions on a fix?
I'm using 2 lawn batteries ran in series through 6 gauge wires. I'm curious, when running in parallel does that double my CCA's? The batteries easily turned over the engine.
Also I had to ground to the gen head cover, I couldnt get the original ground unbolted as it was to rusted. Will that cause any problems? I had 28volts at the batteries once the gen was running.
It put out 110 at 60hz once running no problem. I hooked up a 1,000 watt space heater and it didnt even register on the load meter or change the rpms, the gen didnt even notice the load.
Now to order another carb and get the second one on the trailer running.
