Warner Robins, GA to N. GA XM818
sterlun
10
Morganton, GA
Hey guys, I'm gonna need a tow from WR to Morganton, GA 30560. It's about 200 miles. Truck is an XM818 w/o w and has dead batteries. Also has rear torque rods coming loose on right side which is why I don't wanna drive it.
EUC still pending. Need the run probably in the next 50 days depending on when they get it approved. Obviously within 5-10 after they give the go.
jwaller
19
Columbia, SC
it would be cheaper to chain up the rear axle and drive it home but to each his own. btw there are a few dot stops between you and there so be careful.
sterlun
10
Morganton, GA
Yeah that would be great but the rear axle torque rod is off completely and the forward rear axle torque rod has walked almost all the way out.
SETOYOTA
450
georgia
warner robins towing 478-922-1172 . Also i could pick it up and store until you can get it home.
SETOYOTA
450
georgia
to make it clear i have no connection to WR towing. i have used them with good results. They have drop deck and drive on trailers and can haul most any type of equipment.
