- 34,012
- 1,807
- GA Mountains
I'll get it loaded come **** or high water.
That is fine Kenny.. I will have Speddmon bring it to his place from the rally. I have some of his stuff here anyway. However you can fit it is fine just make sure there is no open holes to fill with dirt or water. Its coming from Port St Lucie ? bbf..The TC is supposed to make it to my house. I'll do my best to get in on the truck. I have 2 M116A3s going in the bed and the M116A2 with the SECM body on it. I have a crapload of stuff to fit in limited voids of space. Lane, I may have to de-crate the thing to get it on board but if that's OK I'll get it to the rally.
I agree I dont know how I did anything before I got my wrecker. Also and I know your pretty good about stuff and a T case is hard to run off with.. I just don't want to have a "Haspin disappearing fuel tank incident." I don't know if AmGeneral ever did get it back??. I felt bad but could do nothing about it..Sheldon will deliver it Thursday of Friday and I'll work it from there! How would I survivie without a wrecker!
Yes, we had already considered a loadout area for heavy stuff that requires a wrecker/hoist to move.clinto, do you have a flat load/unload area, ill have the 819, I think Joel have his crane deuce, and PB will have his 816?, maybe more , this area needs access to all sides and maneuver room , we could have them side by side, spaced so trucks can access both the side and also the rear
I don't see why not, assuming there aren't campers/rv's using it. I believe the person who rents those rv spots on the end gets use of the space all the way to the fence. So if someone is in that end spot, we'd have to ask if we could use it.Clinto, what about the road right outside the pasture gate? We may be able to hook that up for crane work. Not the main road but the one that runs parallel to the fence (IIRC).
BFR, that's certainly doable.
marking the loop might be a little more difficult.
We'll see what we can do.
