sandcobra164
- 288
- 83
- Leesburg, GA
I just installed new Firestone T831's 11X20's on my truck and now the truck wants to wander around on the road. I've checked the steering box bolts (65 ft lb.), adjusted the steering box as outlined in the tm, ensured the drag link is tight and lubed, inpected my tie rod ends and increased front tire pressure to 70 lbs. The sum of those changes helps and I'm not sure which one's are helping and which one's did nothing. I'm considering raising the pressure to 90 lbs and see if that has any effect. I don't think the front bearings are bad as they felt fine while I was changing over the tires and had the front end jacked up. I have considered that it's just nature of the beast with the wider tires. I never noticed this with the NDT 9X20's. Maybe my new tires just need to wear in some?
