K9Vic
- 7
- 38
- Fort Worth, TX
Great info here, I have like 10gallons of used motor oil so I will be filtering that and adding to my fuel. I always used Diesel Kleen added to my fuel, but used oil is cheaper
I add 2 stroke oil to all my 6.2's. It makes the engines run quieter and seems to idle smoother. I can't tell any difference in power or MPG.
According to this, soybean biodiesel @ 50:1 mix worked best. Any of you guys think running clean veggie oil in small quantities would be better than 2-stroke or used motor oil?I think 2-stroke is better than engine oil for adding lubricity in fuel. It certainly is better than used oil. Check out the attached fuel additive study.
