prattcobra
- 0
- 0
- Fowlerville mi
I have a 78 813 that i just got and when i downshift from 2nd to first the gears want to grind. If i come to a straight stop its ok shifting from 1st to second.
Also on the transfer case there is a hose with a grease fitting and the hose is leaking something is there anything except greese in there and what is it for? the hose is cracked.. I just got this from oshkosh and there is a few things I need to get addressed.. They also put a valve stem on that is too long and I can't check the air pressure or add air since it at the brake drum. There is onlt one wheel like this.
i wonder if it will be easy to fix.
I also have a wheel cylinder that is leaking since they said they put all new. WTF.. I'm pissed is it easy to replace that myself looks like I will be doing the repair..
