msisco
- 0
- 0
- Costa Mesa, Ca
So my transmission is not shifting in or out of 3rd gear so well. When the truck is cold it will not shift into 3rd at all and once warmed up 20+ minutes it will shift into 3rd and I can down shift into 3rd but it will often grind. To make matters complicated the transmission shift patern does not match the dash plate shift pattern. 4th and 5th gear are reversed, meaning my 4th gear is down to the right and 5th is up to the right when the dash plate shows the opposite. The truck also seems to bog down when shifted into 3rd or forth like the gearing is too tall. The truck seems to pull strong in 1st and 2nd but 3rd and 4th seem like it is lacking power. It will cruise 60 mph in 5th at approx 2200 rpm.
I am thinking I may be in for a pandoras box rebuild or I might just replace this trans. Has any out there done a swap? How hard was it? Can an average mechanic do this or is this a major project? Any one have ideas on this?
1954 M54
465-LDT engine dated 1989
Thank You!
Mike
1954 M54
Thank You!
Mike
